Thread: Stair cut line display in 3 riser stair
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default
    I have a stair with 3 risers that is automatically displaying a cutline. Any way to get rid of the cutline? The plan cut plane does not go through this stair--it is all projected.
    Thanks
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: Stair cut line display in 3 riser stair
    Take a look at your stair with either a section or elevation. Either your cut plane is set low & is cutting the stair, or you have a base offset on the stair, pushing it up into to the default cut line value (4')
  1. 2014: Stair Riser
    By johntoddflannery in forum Revit Architecture - General
    Last Post: 2014-02-28, 04:46 PM
  2. 2013: Stair plan show more riser line
    By chunji18 in forum Revit Architecture - General
    Last Post: 2012-10-19, 04:54 PM
  3. End monolithic stair with riser??
    By cbaze in forum Revit Architecture - General
    Last Post: 2009-09-08, 04:28 AM
  4. slanted riser on monolithic stair
    By t1.shep in forum Revit Architecture - General
    Last Post: 2008-06-10, 05:19 PM
  5. Stair Riser to Max at 7.5"
    By residarchitect in forum Revit Architecture - General
    Last Post: 2005-06-30, 04:55 PM
