Thread: Single Viewport modification
    2006-04
    85
    Default Single Viewport modification
    Hi, the (attached) macro behind the Single Viewport command is way over my head, has anyone out there got the patience to explain it to me? I would like to modify it so that it saves the 'current layer', creates a viewport and puts it on a 'Viewport' layer (existing) and then restores the 'current layer. If I can get that to work I might do something similar with dimensioning.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Single Viewport modification
    Hi David,
    Please note I have *moved* this thread from the AutoLISP Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Richard
    Forum Moderator
    2002-01
    jUSt Here (a lot)
    6,836
    Look for this bit of code in the macro
    ^C^C_-vports _si
    That bit of code handles the vport command with the single option. After the ^C^C, you could add some code to save the current layer, make or set your viewport layer and then continue with the rest of the code. Then after _si, you could add some code to reset the current layer back to the layer prior to running this code.
  1. Replies: 13
    Last Post: 2011-09-10, 11:16 PM
  2. Single mouse click to edit single line text
    By cjshaw in forum AutoCAD LT - General
    Last Post: 2007-02-14, 03:59 PM
  3. Replies: 2
    Last Post: 2006-06-16, 07:06 AM
  4. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
  5. Replies: 4
    Last Post: 2005-10-06, 01:00 PM
