Results 1 to 10 of 17
Thread: Revit 2010 Network License Manager
    2004-08
    Syracuse, NY
    621
    Default Revit 2010 Network License Manager
    Is anyone else having trouble with this. We are having an awful time using the network license manager in 2010. Many workstations are getting this error message (see attached). I am not really sure what this "Use Extension" thing is either.
    Jason Coe, Design Technology Manager
    Ashley McGraw Architects
    Syracuse, New York
    ____________________________________________
    "Nothing happens by chance and coincidence is when God wishes to remain anonymous"
    http://revitecture.blogspot.com
    2006-01
    4,516
    Default Re: Revit 2010 Network License Manager
    Were not getting the message over here, unless we leave Revit 2010 dormant for a long period of time. Then it gives the license back to the server...
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
    Member vandelay's Avatar
    2006-01
    Albany, NY
    30
    Yes I have seen this error and notified Autodesk subscription on the problem. That was last week and I was told that I would be notified when the problem was fixed.
    We were trying to run a previous version of revit that should have been included with our license file.
    2003-01
    31
    not sure if this is your problems...but
    http://allthingsbim.blogspot.com/200...g-problem.html
    I could stop if I wanted to eldad's Avatar
    2004-01
    230
    Quote Originally Posted by jcoe View Post
    Have you upgraded your LMTools?
    the old version does not support casscading licenses.
    Eldad Asoulin
    Integrator Architecture Engineering Construction
    KarelCAD
    www.karelcad.com.au
    2006-01
    Albany, NY
    30
    Autodesk has resolved the issues with the bad license files. It is also advised to upgrade your lmtools version to the newest version which is 11.5 as eldad has pointed out.
    You might want to contact ABC and have then resend the license files to you. I did not have to give them all my server information again, I just asked that they resend me the files that they sent me before for the 2010 products.
    Good luck.
    I could stop if I wanted to Simon.Whitbread's Avatar
    2003-05
    Auckland NZ
    347
    I've had this posted to Autodesk...
    Its very possible to lose work with Network license MEP 2010 at present
    15:15 start MEP and Create New Project
    15:17 Activate worksharing and create central
    15:20 Closed Central
    15:25 Create Local - add duct and minor mods
    15:39 save local and synchronise central
    15:59 save - license drop out - cannot STC or local
    Cannot use extension to save
    I've tried clicking on the application button - it shows I have a license, but I still cannot save.
    One thing worked...
    Borrow license
    Return License
    Can save now
    How happy can you see users having to do this multiple times
    Simon Whitbread
    Revit Specialist, Auckland, New Zealand
    about.me/simonwhitbread
    "The distance the shotput goes, depends upon the effort that you PUT INTO IT"
    2003-05
    Atlanta, GA
    78
    Autodesk managed to come up with a Hotfix for 64-bit to fix this issue (http://usa.autodesk.com/adsk/servlet...linkID=9242019) but hasn't released anything for 32-bit (to my knowledge).
    When given the option to "Use Extension" keep in mind that this is not an extension of time. It gives you one command then you have to use another extension.
    What has worked for us (when we lose the license) we click "Use Extension" then Save (locally) and exit Revit. Then open Revit again, wait about 30 seconds, then open your project and STC. This seems to work.
    Good luck
    -Ben
    Member nigel.208302's Avatar
    2009-02
    Cape Town, South Africa
    6
    Smile Re: Revit 2010 Network License Manager
    Hi everyone
    I have had +- a month of fighting with my network license. After opening Revit 2010 and viewing the License information I got the following errors -
    Network licensing connection is established.
    License type: Network
    License usage type: <17>
    License behavior: <17>
    License expiration date: error 17
    I have finally fixed the problem. You have to uninstall ALL AutoDesk programs & remove ALL traces AutoDesk from ur machine. Go to http://usa.autodesk.com/getdoc/id=TS45252 & follow the steps.
    Hope it helps some of you. Have a great day
    I could stop if I wanted to brenehan's Avatar
    2007-02
    Melbourne
    225
    Does anyone have any more solutions on this problem. I have tried the Autodesk hotfix but it did not work?
    Thanks
    Brian
    Brian Renehan
    BIM Consultant
    Melbourne - Australia
    http://bimfix.blogspot.com
  1. Inventor suite 2010 Network License via VPN
    By svendb in forum ACA General
    Last Post: 2010-11-17, 04:14 PM
  2. Raster Design 2010 network license
    By clbreinholt in forum Raster Design - General
    Last Post: 2009-06-05, 02:29 PM
  3. Network License manager problems
    By tim.101799 in forum Networks
    Last Post: 2008-11-11, 12:45 PM
  4. Network License Manager
    By khalidisi in forum Networks
    Last Post: 2007-12-03, 02:33 PM
  5. Network License Manager
    By rafterman in forum Revit Architecture - General
    Last Post: 2006-06-29, 12:41 AM
