New to Revit so be kind.
How would you place a sweep at the outside corner of two walls?
I am working on a small park restroom that is CMU with a board and batten on furring. I want to have wider battens to cover the outside corners of the building but Revit does not allow me to place any sweep beyond what it deems the "end of the wall".
I have set up the wall type as 8" CMU, 1-1/2" furring with insulation and 1x boards as the sheathing. I am placing the battens manually using sweeps (small project) but I am having a bear of a time getting the corners to work out.
I have looked though numerous threads but couldn't find anything quite similar enough.
Thanks in advance for any help.
