Thread: Move Corridor in front of surface
    2009-05
    Default Move Corridor in front of surface
    I had create a corridor, in the cut area the surface keep rendered above the corridor, how could i solve this problem?
    i will be very glad to know what wrong i did.
    thank you for helping.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Move Corridor in front of surface
    If you are trying to render, you'll have to create a full finish ground surface by pasting your corridor surface into a copy of your EG. Then render only the composite surface.
    Right now, you have two surfaces in there, and are probably rendering both of them. So naturally, you can only see the one "on top" - the whole point of rendering is to create something like what you would see in real life, which means you can't see through objects in a rendering.
  1. Move a corridor
    By alexanatalia in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-08-17, 02:15 AM
  2. Corridor surface
    By tim_newsome in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-08-05, 04:42 PM
  3. move object to front?
    By jessica.146534 in forum Revit Architecture - General
    Last Post: 2010-06-28, 12:54 PM
  4. I create a Corridor Surface but no Corridor Surface appears?
    By eraska in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-08-21, 09:50 PM
  5. Corridor to Surface
    By jsnyder.105561 in forum AutoCAD Civil 3D - General
    Last Post: 2006-02-13, 04:37 PM
