HOW CAN I BREAK ALL THE LINES THROUGH THE INTERSECTION IN ONE TIME FOR STRUCTURAL DESIGN PURPOSE
First - I moved the post so you can find where to post technical questions.
Second - use the trim command and the Fence option.
Make the objects you wish to trim between your cutting planes and then use a Fence to draw line segments through the offending object parts to cut them out.
