I am at a complete loss, if I use a "Do While...Loop" I get the error "out of memory" If I use a "For Each....Next" loop and try to build a collection without specifing a range I get "out memory" error and if I specify a range I get a type "mismatch error" what am i doing wrong. It seems like this should be something really simple.
Sub AddLayers()
Dim layerObj As AcadLayer
Dim color As AcadAcCmColor
Dim LayerName As String
Dim LTname As String
Dim col As New AcadAcCmColor
Dim colLayerList As New Collection
Dim i As Integer
Dim LayerValue As Variant
Dim LayerList As Range
Set xlbook = GetObject(SupPath & "06Layers.xls")
'set reference to Excel file
Set xlsheet = xlbook.Sheets("MasterLayerList")
'set reference to the worksheet
Dim entry As AcadLineType
Dim found As Boolean
found = False
col.ColorMethod = AutoCAD.acColorMethodByACI
Do While xlsheet.Cells <> "" Or xlsheet.Cells <> 0
i = i + 1
LayerName = xlsheet.Cells(i, 3)
Set layerObj = ThisDrawing.Layers.Add(LayerName)
Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16")
col.ColorIndex = xlsheet.Cells(i, 4)
layerObj.TrueColor = col
LTname = xlsheet.Cells(i, 5)
layerObj.Linetype = LTname
For Each entry In ThisDrawing.Linetypes
If StrComp(entry.Name, LTname, 1) = 0 Then
found = True
Exit For
End If
Next
If Not (found) Then ThisDrawing.Linetypes.Load LTname, "acad.lin"
Loop
End Sub
or
Sub AddLayers()
Dim i As Integer
found = False
colLayerList.Add xlsheet.Cells.Value
For Each LayerValue In colLayerList
i = i + 1
found = True
Exit For
End If
Next
Next
End Sub
