Thread: Objects not visible in section views
    2001-01
    81
    Angry Objects not visible in section views
    First let me start with a little background. I am running Revit Struct 2009. I have an overall structral model that has 3 models linked into it (steel framing imported from RAM Struct). I put the foundations in my overall model. Here is my problem. I cut a section & go to view the section & the foundations show up (modeled in overall) but nothing from the linked models shows up. HERE COMES THE KICKER. When I flip the section mark (the same section mark & location) everything shows up proprerly. What is going on? Does anybody have any ideas???????
    2008-04
    270
    Default Re: Objects not visible in section views
    I have had a similar problem in the past with Structural Connection families....
    There seemed to be a bug in Revit that made the system get confused when representing structural connections.
    Connections were visible in sections even though they were 'outside' the sections view range/extent. Also structural connections were not appearing 'hidden' when behind an object.
    The work around was to put all structural connections onto the generic model category in the family category menu.
    I know that isn't much help with your situation, but it could be a similar bug..
    Have you tried submitting a support request to Autodesk?
    Regards
    2001-01
    81
    No I haven't put in a support request. I will do that.
    2001-01
    81
    Quote Originally Posted by tknapp View Post
    Autodesk support hasn't been able to figure this one out. The Tech. Support rep. is submitting my files to the development team for futher investigation. Sounds like a bug! Guess, I will just wait. I had to do some creative work arounds to get the job out the door.
    2001-01
    81
    O.K. Here is what Autodesk Support has told me . . . .
    "I am very sorry for the delay while the development team was investigating the files. They have confirmed that there is an issue with back clipping that needs to be resolved. In the meantime, they have suggested setting the Far Clipping parameter in the sections' Properties to "clip without line" - the elements should then become visible. I hope this is an acceptable workaround for the time being. Again, I apologize for the delay. If you have any questions please do not hesitate to send an update to the case."
    2015-11
    8
    I can confirm that this issue still occurs with Revit 2017.
  1. Section Views, fix the seperation and vizability across plan views
    Last Post: 2012-07-24, 02:46 PM
  2. 2011: Creating, or Updating Section Views from 3D Piping to a 2D Section
    By Drafter1981 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-11-23, 11:46 AM
  3. Pipe network structions to show structure section in section views
    Last Post: 2010-10-06, 01:04 AM
  4. Objects drawn in Section not Visible in Plan
    By Alex.149038 in forum Revit MEP - General
    Last Post: 2008-09-02, 02:15 PM
  5. Section Views Not Visible
    By troy.crandell635379 in forum Revit Architecture - General
    Last Post: 2008-04-15, 05:57 PM
