Thread: Navisworks 64-bit not exporting from Acad '09
    2006-04
    Danvers, MA
    2
    Question Navisworks 64-bit not exporting from Acad '09
    I am using 64-bit versions of both Navisworks Manage '10 & Acad '09. I installed the 64-bit exporters and loaded the arx files into Acad. When I use the export command (nwcout) nothing happens. No error, no "save target as" dialog. It just sits there until I hit escape.
    This problem happened with Navisworks Manage '09 and I was hoping it would be resolved with the new version, but it looks like it's not. Anyone get this same problem?
    2000-01
    Seattle WA USA
    5,859
    Default Re: Navisworks 64-bit not exporting from Acad '09
    Quote Originally Posted by mvecchione View Post
    It may be that the Navisworks 2010 ARX file will only work with AutoCAD 2010 since ARX files needed to be recompiled for AutoCAD 2010. A 2010 ARX will not be compatible with earlier versions of AutoCAD.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2015-12
    2,095
    Could it be the filename dialog is located off-screen somewhere?
    2006-04
    Danvers, MA
    2
    Quote Originally Posted by RobertB View Post
    It does work in Acad '10, thanks! (We have a subscription license). My only issue now is waiting for Quickpen to release an '10 Pipe Designer 3D enabler in 64-bit, not holding my breath on that one since they haven't even released an '09 64-bit one...
    2003-12
    Chicago
    206
    Actually, if you contact QuickPen directly, they will send you a 64 bit object enabler.
    I ran into a similar issue with our HVAC subcontractor and they sent me the necessary object enablers for 64 bit AutoCAD 2009.
  1. Revit Phasing exporting to Navisworks
    By timsea81 in forum Revit MEP - General
    Last Post: 2011-08-19, 04:14 PM
  2. Revit Phasing exporting to Navisworks
    By timsea81 in forum NavisWorks - General
    Last Post: 2011-08-19, 12:57 AM
  3. Navisworks Exporting
    By stevens.b in forum NavisWorks - General
    Last Post: 2010-02-10, 09:43 PM
  4. Exporting Revit MEP to Navisworks
    By rj_ray2001 in forum NavisWorks - General
    Last Post: 2010-02-10, 06:11 AM
  5. Exporting an Elipse to Navisworks
    By raghavendra.bhat in forum NavisWorks - General
    Last Post: 2009-09-26, 04:03 AM
