I've got this bit of code (below) that I have inherited in an ASP.NET project. Apparently, I can no longer use the line in red as I get this error. Can anyone rewrite that to current standards? All help is appreciated.
The lines in blue will probably have the same problem.
Code Error
'System.Data.DataSet.Tables.get': cannot explicitly call operator or accessor
public ArrayList GetAlItems()
ArrayList objArray = new ArrayList();
DataSet objDataSet = FillControls.FillDataSet("ALL_ITEMS", ConnString);
int iDataSet = objDataSet.get_Tables().get_Item(0).get_Rows().get_Count() - 1;
if (iDataSet != -1)
do
try
ListItem objListItem = new ListItem();
objListItem.Text = objDataSet.get_Tables().get_Item(0).get_Rows().get_Item(iDataSet).get_Item(1).ToString();
objListItem.Value = objDataSet.get_Tables().get_Item(0).get_Rows().get_Item(iDataSet).get_Item(2).ToString();
objArray.Add(objListItem);
catch (Exception e)
string message = e.Message;
iDataSet--;
while (-1 < iDataSet);
return objArray;
