Results 1 to 6 of 6
Thread: Corridor Problems
    2009-06
    3
    Default Corridor Problems
    Hello i am new at Cvil 3d. When I make corridor on my surface I do not get show the excavations and embankments on side of my road. And I dont konw what I am doing worond.
    Thanks Aleks
    2006-12
    Loveland, CO
    734
    Default Re: Corridor Problems
    Without looking at your file, I would guess that you need to target the existing ground surface for your daylight subassembly.
    2007-06
    271
    I second what Brian said, you have no targets in your corridor properties.
    2009-06
    3
    How and where can i do that?
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Go to the Parameters tab In the corridor properties and pick the Set All Targets button. You should see Surfaces listed under Targets. Pick where it says <Click here to set all>. If you do not see surfaces listed you need to add a subassembly that can target a surface to your assembly.
    2009-06
    3
    ok perfect i made it. Cool thanks.
    But now i have a problem to export it because when i export it to xml or vsp3d i get error by corridor. What i am still doing wrong? What did i miss / overlooked??
    P.S: Picture of error!!
  1. Corridor LandXML to include the true corridor & associated objects
    Last Post: 2015-11-16, 11:00 AM
  2. 2014: Corridor Section Editor Display Problems
    By caparks553428 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2014-09-05, 05:25 PM
  3. 2014: Corridor Surface Problems
    By FBL - Desirea in forum AutoCAD Civil 3D - Corridors
    Last Post: 2013-10-25, 10:34 PM
  4. 2011: Surface from corridor problems.
    By gosgood73139200 in forum AutoCAD Civil 3D - General
    Last Post: 2013-04-25, 06:19 PM
  5. Corridor Intersection Curb Return Problems
    By georgeh in forum AutoCAD Civil 3D - Corridors
    Last Post: 2012-05-03, 02:34 AM
