Results 1 to 6 of 6
Thread: Annotative Blocks lose annotative properties
    2008-10
    New Hampshire
    14
    Unhappy Annotative Blocks lose annotative properties
    Is anyone expierencing annotative blocks losing there annotative features when they are exported and reimported back into a dwg? Using C3d 2009.. thanks
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Annotative Blocks lose annotative properties
    You mean in an "Export to 2007"? I haven't paid much attention, but that wouldn't surprise me, since Annotative objects did not exist in 2007 (they were added in 200.
    2008-10
    New Hampshire
    14
    Yes, what I am trying to do is build a list of block symbols of explorations used for Geotechnical/Environmental work. I currently have a library of symbols and I am looking to convert them to Annotative. But when you export them out after making them annotative they lose their properties when you insert them. ITS a Bummer. Thanks
    2007-10
    41
    Export or WBLOCK? Of course if you export them you will lose the annotative properties, but if you use the WBLOCK command, everything should stay annotative. Your best practice is to create the object, run the block command, assign the annotative property in the block command dialog, then wblock out.
    Let me know if it works,
    2008-01
    2
    Wink Re: Annotative Blocks lose annotative properties
    Export is for sending C3D drawings to another user who does not have C3D. It dummies down the objects.
    Remember that anyone using a pre 2008 version of AutoCAD will not be able to use your annotative blocks. Look into SAVEFIDELITY in your help files for more info. Make sure that is turned on in your options.
    If merely saving down to another version, use SAVEAS and select the 2007 drawing version. That should not affect your annotative property. As long as you are not using 2010 you should need to be converting versions at all.
    You can use Design Center to organize and transfer blocks to other drawings. It's great for working with block collections. You can preview all your blocks and insert them.
    Also you can create a tool palette directly from your drawing file using Design Center. Tool palettes can be exchanged and shared with other users. It's a great way to organize block libraries like you are creating.
    2008-10
    New Hampshire
    14
    Thanks, about the WBLOCK, I was not checking off the annotative box. But I also use a third party tool call "TOOLPAC" ver11.0. It's a great tool from DOTSOFT and it helps with a lot of bottle neck issues. So when i was saying export i was referencing Toolpacs block export command. Thanks for all your input.
  1. 2011: annotative text and annotative block failure
    By kuruczregina in forum ACA General
    Last Post: 2012-03-25, 06:56 PM
  2. Annotative MEP Blocks not doing the annotative thing
    By pauljordan in forum AMEP General
    Last Post: 2010-07-07, 10:38 PM
  3. Base points in Blocks not behaving when I make Blocks use annotative scale
    By dood in forum AutoCAD Land Desktop - General
    Last Post: 2007-06-10, 04:51 PM
