I am running Acad 2007
In the past, on this machine, I have been able to select items and then hit Ctrl + C or Ctrl + SHift + C to use copy clip, copy base or properties
Autocad is now requiring to enter these command 1st, is there a reason or a fix for this?
Update - Using Icons or regular keystrokes for these commands work fine just no Ctrl + Commands.
Solution:
Set Variable QAFLAGS to 0
Thank you in advance,
Andre
