Results 1 to 10 of 11
Thread: C and MC Channel Dynamic Blocks
    2008-05
    5
    Default C and MC Channel Dynamic Blocks
    I just wanted to post a couple blocks that I have wanted for a while but couldn't seem to find. I realize that there is a Channel dynamic block in the structural tool palette in ACAD 2010, but it does not have filleted corners and does not have all the AISC sizes.
    So here are the C Channel and MC Channel blocks that I finally had time to make. All the dimensions taken from AISC v13.
    2008-12
    175
    Default Re: C and MC Channel Dynamic Blocks
    You must be using a version newer than 2009? I only get a single block.
    John
    2006-11
    Martinsburg, WV USA
    186
    Quote Originally Posted by jnoon View Post
    John
    same here, I'm running 2009 and just get a single block
    2003-11
    Ashland, Kentucky
    64
    Try exploding the block after you have it inserted in your drawing, then you should be able to see the other properties of the block.
    Jim Fields
    CAD Design
    Site Development Coordinator
    Trace Creek Construction, Inc.
    www.tracecreek.net
    "Man's mind stretched to a new idea, never goes back to it's original dimensions." - Oliver Wendell Holmes
    2006-11
    Martinsburg, WV USA
    186
    Quote Originally Posted by jfields.61630 View Post
    nope..still just a single block, and when I explode it, it becomes broken lines and arcs
    2007-07
    65
    It is using 2010 dynamic constraint instead of dynamic block parameter and action.
    2009-01
    3
    thanks alot
    2010-07
    15
    Exclamation Re: C and MC Channel Dynamic Blocks
    Quote Originally Posted by lawrencerobinson5 View Post
    Hi Lawrence,
    it passed already 1 year from your post... but I have a question!
    I downloaded your dynamic block and it appears that all sizes of channel have the same radius.
    Do you know how to scale the radius? According to rules, the External radius must be 1/2 of Web thickness and internal one=1/2 of flange thickness.
    Thank you.
    Beginner!
    2012-02
    2
    Question Re: C and MC Channel Dynamic Blocks
    Would anyone happen to know where i could find bolocks of 7" ship channels
    All weights. 17.6, 19.1, 22.7
    Thanks
    DZ
    I could stop if I wanted to clshade's Avatar
    2009-01
    B5
    476
    Google or create.
    Most build these DynBlks when needed.
    Maybe someone who happens across this will have one.
    (If I had one I would post)
    Charles Shade LT 2013
    www.cshadedesign.com
  1. Dynamic channel and L shape Metric size
    By kaldenecker.janos in forum Dynamic Blocks - Sharing
    Last Post: 2011-03-01, 04:45 PM
  2. Replies: 7
    Last Post: 2007-02-05, 12:11 PM
  3. Replies: 1
    Last Post: 2007-01-05, 12:38 AM
  4. Copied dynamic blocks not dynamic anymore..
    By kwong in forum Dynamic Blocks - Technical
    Last Post: 2005-07-08, 10:49 PM
