Results 1 to 10 of 13
Thread: Importing Sketchup files to Revit and asigning render materials
    2004-10
    Yorkshire, UK
    402
    Default Importing Sketchup files to Revit and asigning render materials
    We are having issues importing a Sketchup file into Revit and changing the materials to revit ones for rendering.
    We have tried:
    (1) Modelling in Sketchup using components for things like walls, then putting them on a layer and importing into Revit. If we try this method, and alter the Imported Objects material for that layer, it still renders in a default white material. This is our preferred way of working in sketchup.
    (2) If we model in Sketchup and dont use components (i.e. use groups instead) we can change the materials in Revit. This is not how we generally work in sketchup.
    Is this a bug/known issue with Sketchup import?
    Thanks
    2009-01
    59
    Default Re: Importing Sketchup files to Revit and asigning render materials
    Why not just model in Revit? I've created multiple proposals in hours with the program information, square footage, and many other parameters built into the model.
    Sorry to not answer the question...
    2004-10
    Yorkshire, UK
    402
    That is what I would usually do - I dont know how to use sketchup myself.
    We have a Sketchup user who doesn't know Revit and just want me to do some renders of a model that she is going to make. I need to let her know how to model it in sketchup so that it imports into Revit in a way that I can change the materials for rendering.
    2006-01
    4,516
    Teach her Revit, lol...
    2007-03
    Salt Lake City
    360
    My guess is that it isn't really a bug or issue, but more of a just the way it is. Without me really looking into it, I would think of it this way...
    If you build a family in Revit, and nest in another family, but only the main family has material properties, you won't be able to control the material of the nested component.
    I think that is more or less what you're getting in Sketchup. When you make something a component in Sketchup, it treats it like it's own family and needs to be edited and saved seperately, whereas, if you just group things together you can still control them natively.
    So, when you import a Sketchup model with components instead of groups you are only able to modify the main model and the component portion maintains it's original settings.
    So, I've a couple thoughts. One, start using groups in Sketchup. She could model everything in Sketchup in your preferred workflow (with components) and then explode the components before sending to Revit.
    Two, you could bring in each Sketchup component separately into a Revit Family as if you were nesting them.
    Third, use Revit. I actually prefer to model walls, windows, floors, roofs, etc in Revit (since that is what it's designed to do). In sketchup you have to group, and make components and use layers, and it can become a pretty big mess if you miss something. So once I have it started in Revit, I'll export to Sketchup and tweak and add you custom content that's easier to model in Sketchup.
    2005-06
    84
    We were faced with a similar issue. We purchased Vray for Sketchup and it turned into a good workflow option. It's easy to port building geometry to Sketchup from Revit and quickly get decent renderings, while using the huge inventory of available "stuff" out there for the Sketchup environment. This is for early design work of course.
    2006-10
    67
    Looks like you're looking for something to render sketchup models. In which case Kerkythea is a decent and amazingly free program that is pretty simple to use: http://www.kerkythea.net/joomla/.
    Pittsburgh, PA USA
    1,906
    No, the OP was asking how to get Revit materials assigned to a Sketchup object once it is imported into Revit. I am facing this issue myself, since a sketchup object was the only way I could get an elevator machine into a complicated elevator family.
    2009-04
    London, UK
    146
    Hi,
    What you could do is to import your skp file into a mass family > finish family > create wall/ roofs etc. by face.
    Check out this video:
    http://www.youtube.com/watch?v=WsE1hNOfb48
    REgards,
    Stephan
    2004-05
    St. Louis, Missouri
    3,135
    Red face Re: Importing Sketchup files to Revit and asigning render materials
    Or--Export to 3D Autocad from SU, import the Acad into Revit and apply materials
    via Imported categories-----have had mixed results with that.
    LOL
    cheers
  1. 2013: Apply Revit materials to imported SketchUp objects
    By Bill Gilliss in forum Revit Architecture - General
    Last Post: 2012-12-03, 11:21 PM
  2. Problems Importing SketchUp Files
    By kim.74445 in forum Revit Architecture - General
    Last Post: 2009-11-25, 04:49 AM
  3. How to: Map 3D DWG render matl's to Revit/MR materials
    By Graham Briggs in forum Revit - Rendering
    Last Post: 2008-11-20, 12:02 AM
  4. Importing SketchUp into Revit
    By gwcrawford in forum Revit Architecture - General
    Last Post: 2006-08-21, 06:18 PM
