Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Importing Sketchup files to Revit and asigning render materials
  1. #11
    Default Re: Importing Sketchup files to Revit and asigning render materials
    I have seen the question of how to bring a SketchUp model into Revit asked on several sites. The inevitable response from some Revit user is "Why?"
    Given the strengths of SketchUp as a conceptual design tool it seems only natural to want to leverage these strengths by porting what has been accomplished in SketchUp to the best available tool for design development and construction documentation, which is Revit.
    The respondants to the question point out that they are able to accomplish in Revit anything that can be done in SketchUp. When one searches Google images for SketchUp and conceptual design, the results are myriad. Changing the search terms to Revit and conceptual design yields results mainly from Autodesk promotional pieces and their duplication on various sites.
    If there is a question that ought to be asked, it is why this should be so.
  2. #12
    2006-01
    4,516
    Stour-
    Welcome to the forums.
    I think you may misunderstand why some of us keep asking that question in return, when faced with the question of importing sketchup models.
    You *CAN* import a sketchup model, and head several ways with it, depending on what you want to do with it. If its just for show, you can manage its rendering aspects somewhat successfully through the Imported Objects dialogue. If you want it to TURN IN to Revit objects, you can import it in to a mass family, and Wall by/Roof By/whatever,
    What a lot of us have found- however- is not solely a Revit limitation, but is basically a limitation anytime you mix more than one medium together. Things dont respect "replace" or "remove" the way they do "alter." So you have to methodically go bck to sketchup to edit the masses, hoping to reimport them in to masses to have them updatable for geometry done with Building Maker. Same with rendering materials.
    I guess the reason i answer "dont bother," is for me its not about "can i use the skethcup model," but its about "can i use the sketchup model and be more efficient." If i cant, i can just rebuild it. The myriad of times ive tried, it was faster to remodel it in Revit.
    If we disagree on Revits usefulness in SD or concept, all is well. But for what its worth, we love Sketchup for its artistic flair (though in house we argue about the validity of that flair. I find it useless, but i concede that some people here love it.) So we actually DO our concept and SD in Revit, then export out to SU just for the goofy image filters, LOL.
  3. #13
    2014-06
    If you have Sketchup PRO, then you can export a 3D sketchup model to a 3D autocad model by exporting it as a dwg file, but that can only be done with sketchup pro, you cannot save or export as any readable file for revit or autocad with regular free versions. Also, if you want to convert it from revit to sketchup, and the sketchup program that you have can't read dwg files, then export through revit as a dwg file, then if you happen to have Autodesk 3DS max, even if you don't know how that program works, open it up, go to the pull down option in your options in the top left hand side and go to import, then you can import the dwg file, once it's been imported, now go to the same option pull down and go to export, now you can export it to "3ds" file type, and that can be imported into sketchup and be readable.
    -3D modeler and Architecture/Furniture Drafter
  1. 2013: Apply Revit materials to imported SketchUp objects
    By Bill Gilliss in forum Revit Architecture - General
    Last Post: 2012-12-03, 11:21 PM
  2. Problems Importing SketchUp Files
    By kim.74445 in forum Revit Architecture - General
    Last Post: 2009-11-25, 04:49 AM
  3. How to: Map 3D DWG render matl's to Revit/MR materials
    By Graham Briggs in forum Revit - Rendering
    Last Post: 2008-11-20, 12:02 AM
  4. Importing from Revit (and using Materials)
    By jdshanks in forum VIZ - General
    Last Post: 2006-08-31, 02:53 AM
  5. Importing SketchUp into Revit
    By gwcrawford in forum Revit Architecture - General
    Last Post: 2006-08-21, 06:18 PM
