Results 1 to 6 of 6
Thread: Drawing Index
    2005-09
    68
    Default Drawing Index
    Hello,
    I was wondering is there a way to use the attributes in the title block to create a drawing index.
    I'm using 2008. I see alot of threads for Revit, and from what i'm reading it would solve my need. I don't see my company purchasing it, so I have to do with what I got.
    Thanks.
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,790
    Default Re: Drawing Index
    Quote Originally Posted by lee.johnson View Post
    What is "it"?
    What you want is possible and this is what document management software does. Generally, you would extract the info to a database and then use the db's reporting functions to generate a report. You can check the cad mgr forum for some discussions on document management. If you have experience working with MS Access or some similar db program, you should be able to do it. I would recommend using .NET to do it though, or at least vba as it would be easier to work with the db's api in those evironments.
    C:> ED WORKING....
    2005-08
    1,043
    You can use Lisp with ObjectDBX to get the information you want. Here is a thread at another site that shows how it can be done.
    [ http://www.theswamp.org/index.php?topic=8661.0 ]
    Also I think you can use Sheet Sets. I don't use them, but I see a lot of posts of some of the stuff they can do, and I think your request is one of them.
    Turlock, CA
    4,790
    However, you didn't say if you just wanted a single list, one time or you wanted to maintain a list. The approach would be different for each.
    C:> ED WORKING....
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Folks, what about SheetSet Manager?
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2005-08
    1,043
    Quote Originally Posted by RobertB View Post
    Quote Originally Posted by My first post in thread
  1. Drawing Index Order?
    By tjohnson.255471 in forum Revit Architecture - General
    Last Post: 2010-07-30, 04:01 PM
  2. Drawing index yes/no text to just a dot?
    By PWguy in forum Revit Architecture - General
    Last Post: 2006-04-11, 11:29 AM
  3. Drawing Index
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2004-08-30, 08:51 PM
  4. Drawing Index
    By tjk0225 in forum Revit - In Practice
    Last Post: 2004-06-05, 12:46 PM
  5. Drawing Index
    By BomberAIA in forum Revit Architecture - General
    Last Post: 2004-02-22, 03:17 PM
