Results 1 to 7 of 7
Thread: Wall Split Region Vertically
    I could stop if I wanted to sthedens's Avatar
    2006-01
    306
    Default Wall Split Region Vertically
    I know how to create horizontal split regions in section view and assign layers to create a horizontal band of material change, e.g. brick to split face.
    I'm looking for a way to create split regions vertically in plan view (not section view).
    See attached wall elevation image for an example of what I'm looking for.
    2004-01
    Columbus OH
    465
    Default Re: Wall Split Region Vertically
    A curtain wall system with custom mullions and panels would work nicely for this scenario
    2006-01
    306
    Amazingly useful utility, those curtain walls.
    So, now I'll have a curtain wall that's really a brick/CMU cavity wall to go with my curtain wall that's really a storefront window and my curtain wall that's really a stadium dugout railing.
    Now I just need to find out how to make curtain walls horizontal so I can have curtain wall floors, ceilings and roofs.
    2004-01
    Columbus OH
    465
    If you start with a mass you can use the Curtain System by Face tool to make your horizontal floors, ceilings, and roofs
    Thats probably relying on curtain walls way too much but I can imagine that somebody somewere has an idea were it would be perfect.
    2006-01
    306
    I hope no one construes my remarks as hating on curtain walls. I think they are one of the coolest features of Revit. The problem is they may be TOO cool. Their flexibility makes them an easy fixed to difficult situations.
    We have to remember that this is BIM. It's not just about the "M" part. It's also about the "I" part. A door knows it's a door and belongs in a wall, etc. Every time I try to get cute or clever by fooling Revit, it comes back to bite me in the behind somewhere down the way.
    2006-01
    4,516
    That is a very good point, and a lot of the kludgy workarounds that are used in Revit totally mess with the *I* in the B.I.M.
    But also worth remembering, using Curtain Wall doesnt always mean messing with the I. For instance, you used Walls as Curtain Panels in the first iteration of this thread, so they still know theyre walls, as well.
    Also, there is the "I" in Revit, and the "I" everywhere else. You can change the assembly codes for different Types of Curtain Systems, to respect the classifications of whatever objects youre using them for. Again, its a process that you will have to look at in terms of what is the onject youre using the CW tool for, and which PIECE of the Information are you using at different phases of your project. The "Revit Type" or "Revit catagory" may be paramount to US as revit users, at a certain phase of the project, but as it moves on to other wares, it may be less (or more) relevant...
    I use them for Coffered ceilings...
    100 Club iandidesign's Avatar
    2005-03
    130
    You can also embed one wall type within another. Tutorial here:
    http://www.revitzone.com/index.php?o...=828&Itemid=50
    Geoff Briggs
    I & I Design, Seattle
    RAC 2009 on XP
    ArchiCAD 11 on Mac
  1. Split a profile vertically
    By Emmar01 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2011-11-17, 10:35 AM
  2. Revit Bug? - Split object randomly inherits properties of a split region within it
    By Andrew Dobson in forum Revit Architecture - General
    Last Post: 2010-04-07, 12:23 PM
  3. Split Crop Region at an Angle
    By rahm in forum Revit Architecture - General
    Last Post: 2008-12-02, 09:55 PM
  4. Trouble selecting split region
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2007-08-14, 06:22 AM
  5. wall w/ split region causing footing problem
    By dysart in forum Revit Architecture - General
    Last Post: 2007-02-15, 08:36 PM
