grudy
I'm relatively new to Revit, so bear with me. I need to export a Revit file so that I can send the file to be analyzed for daylighting quality. Unfortunately, the company that does this analysis only works with Rhino, Sketchup, and dwg files. I've tried exporting a 3d dwg file from a 3d view in Revit, but I find that the layer structure of the .dwg file is insufficient. Revit lumps all interior walls into one layer, regardless of material, and likewise with exterior walls. I do not want to have to go through the dwg file and manually create new layers for each wall type.
What is the best way to get the various wall types from Revit into another file format that someone with Sketchup, Rhino, or Autocad could use? I do not need the wall types to be named by material necessarily--only that they be given different layers so that someone can apply material settings to them.
