Thread: How to change basepoint of define block
    2009-05
    17
    Default How to change basepoint of define block
    How to create a macro using LISP for change basepoint of a defined block placed in a drawing.My needs are not changing the block placed possition, attribute possition, angle and applied block edit parameter possition .If possible please give as soon as possible.
    with regars,
    hareeshmb
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Default Re: How to change basepoint of define block
    Welcome to AUGI & congrats on your 1st post.
    There's no way of placing a basepoint parameter inside the block using Lisp / ActiveX / VBA ... probably only possible with ARX / .NET. However the ActiveX block object has an Origin property which can be changed:
    (setq blkcol (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object)))) ;Get blocks collection
    (setq blk (vla-Item blkcol "blockname")) ;Get the block's definition object
    (setq pt (vlax-make-safearray vlax-vbDouble '(0 . 2))) ;Create a safearray to hold the 3D point
    (setq pt (vlax-safearray-fill pt '(1000.0 1000.0 0.0))) ;Fill it with the new XYZ values
    (vla-put-Origin blk pt) ;Change the blockdef's origin property to the new point
    BUT!!! This does nothing until you open & close the block in BEDIT. Now you need to entupd each block reference (INSERT) to match the new definition.
    BTW, why not simply BEDIT the block and place a basepoint parameter? Then you can WBLOCK it out and insert browse to other drawings so you can update those definitions as well?
  1. Replies: 5
    Last Post: 2012-12-10, 07:10 PM
  2. save a dwg file without block define
    By ralphtang in forum AutoCAD Electrical - General
    Last Post: 2012-04-27, 07:21 PM
  3. 2011: Dynamic Block - Basepoint
    By przemekmysz in forum ACA General
    Last Post: 2012-01-10, 05:04 PM
  4. basepoint not moving with block
    By cwjean76 in forum Dynamic Blocks - Technical
    Last Post: 2007-12-21, 07:55 PM
