Good day!
Can I switch my Civil 3D 2010 to classic menu view?
Not "Autoacd classic" but "Civil 3D classic"?
Good day!
Best bet is to try to get used to the Ribbon. Autodesk has stopped adding new commands to the menus.
But the Ribbon isn't laid out in the best way yet, so I still sometimes turn on the old-style menus. You can do that by clicking up at that little toolbar at the top-left of the screen, next to the "C", that has the Save/Open/etc. button on it.
If you are having trouble finding an old pull-down menu command on the Ribbon there is a new help feature called "Where is My Command" that should help you find it.
Jeff Paulsen
Unfortunately, Autodesk decided not to put any new C3D commands on the pull-down menus. So if you want to do intersections or quantities or anything else new you have to use the ribbon.
Jeff Paulsen
Torino, YOU ARE THE MAN, THAT RIBBON STUFF SUCKS, THANKS FOR THE MENUBAR COMMAND!
you saved my life. now haw do i remember MENUBAR?
http://www.watsonlisp.com
Artificial Intelligence for AutoCAD
Find detail drawings by text and attribute content!
6000 lines of code and 14 years in development.
