Results 1 to 6 of 6
Thread: tittle blocks using the SSM in the project Nav
    180
    Default tittle blocks using the SSM in the project Nav
    Hi guys,
    If I have an old tittle block that I want to use in ADTs project nav everytime I create new sheet, what is it that I need to do? I also what it to work with fields.
    Thanks
    2001-10
    Arizona
    2,337
    Default Re: tittle blocks using the SSM in the project Nav
    First edit all of the Attributes and insert Fields that you want for standard sheet stuff
    and include the Fields you want to use for Sheet Manager as well.
    Look at the newsheetset command, and follow the Wizard in there you will set
    the resource file location.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    180
    thank you !
    180
    OK here is the answer i was looking for that I found based on your guidance.
    The tittle blocks are created in different layouts on a single template file, then this template files is used to create the sheets in the SSM. I noticed that every time I ask to create a new sheet at the very bottom of the window where in need to name the sheet it displays the template I am using for sheets.
    2001-10
    Arizona
    2,337
    The good news is you have the answer you needed.
    I guess I should edit my message to say,
    "If you see a red barn and a man with a cow, you've
    gone too far"
    The idea was to get you there......
    Be your Best,
    Michael Farrell
    180
    Quote Originally Posted by mjfarrell
    gone too far"
    Yep, you helped me get there indeed ! thank you very much !
  1. Tittle Block Labels
    By fduraes in forum Revit Architecture - General
    Last Post: 2010-03-11, 08:24 PM
  2. Base points in Blocks not behaving when I make Blocks use annotative scale
    By dood in forum AutoCAD Land Desktop - General
    Last Post: 2007-06-10, 04:51 PM
  3. Replies: 12
    Last Post: 2007-06-01, 05:22 AM
  4. Replies: 3
    Last Post: 2006-09-12, 11:17 AM
  5. Transfering Note Blocks and Schedules from project to project
    By jnl in forum Revit Architecture - General
    Last Post: 2005-11-05, 01:59 AM
