Thread: DBConnect
    2008-05
    58
    Default DBConnect
    I want to create a design and then extract all the information of each solid (Layer, Width, Length, etc) into a table in a database. Sort of like the list command, exported into a table. Is this possible? the only use of DBconnect I've read so far is using block attributes. Thanks.
    2007-07
    Jo'burg SA
    4,344
    Default Re: DBConnect
    You can use Tools --> Data Extraction to save it to an XLS or CSV file, then import that into your database.
  1. Dbconnect in Windows 7
    By cadconcepts in forum AutoCAD Customization
    Last Post: 2011-03-02, 09:18 PM
  2. dBConnect
    By matthew.carerros in forum VBA/COM Interop
    Last Post: 2006-02-15, 01:55 PM
  3. dbconnect
    By matthew.carerros in forum ATP Course Wishlist
    Last Post: 2006-01-30, 09:13 PM
  4. dbconnect
    By DFlynn in forum AutoCAD General
    Last Post: 2004-06-18, 11:35 AM
  5. dbconnect
    By thughes in forum VBA/COM Interop
    Last Post: 2004-06-04, 08:00 PM
