Thread: Ceiling Identity Data
    I could stop if I wanted to charliep's Avatar
    2003-02
    Northumberland, U.K.
    341
    Default Ceiling Identity Data
    Doing a RCP (RAC 2009) but noticed the ceilings did not have any data against the mark under Identity Data. Hence the ceiling tag shows blank. Is it usual to not have this data in a ceiling do we have to put the referebce in manually? Or have I missed something out somewhere? Any advice appreciated.
    2015-11
    standing @ the crossroads
    241
    Default Re: Ceiling Identity Data
    I am assuming that you are looking under "Instance Parameters". For the "Mark" value under "Instance Parameters" you will need to fill this in manually. However if you switch to "Type Parameters" then you can enter a "Type Mark" value that will show up on each of the ceilings or objects that you insert into your model.
  1. identity data in type catalog
    By jhs.222310 in forum Revit Architecture - Families
    Last Post: 2010-11-02, 09:45 AM
  2. Stacked walls and identity data
    By clog boy in forum Revit Architecture - General
    Last Post: 2009-05-15, 02:24 PM
  3. Identity data - new param for walls?
    By still.james in forum Revit Architecture - General
    Last Post: 2008-09-09, 11:49 AM
  4. Identity Data
    By harkeychad in forum Revit Architecture - General
    Last Post: 2008-07-20, 09:21 AM
  5. Material Identity Data Paramters
    By rkitect in forum Revit Architecture - General
    Last Post: 2008-03-19, 09:13 PM
