Thread: Download Missing Items From Autodesk
    2009-03
    11
    Default Download Missing Items From Autodesk
    Hey There
    Has anyone tried to download the materials update from autodesk?
    viz2008_materialupdate.exe is the download name
    Everytime i try to install it, it runs very fast (can't see where it is installing) and gives no option for location to install.
    Then when i look for the files they are no where to be found!
    Any tips? Thanks
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,272
    Default Re: Download Missing Items From Autodesk
    Does it just add materials to your existing library? That's why I would assume it runs so fast, because it's just adding the files to your existing installation...
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    If I recall correctly there were instructions posted with that file that said you needed to copy the contents of the install disc to a specific directory in order for the fix to patch the correct files and then run the install wizard to install everything fresh.
    ...or maybe that was for one of the other hotfixs released that year for VIZ...
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
  1. Missing items in AutoCAD DWG
    By ingeneering in forum AutoCAD General
    Last Post: 2011-11-17, 07:32 PM
  2. Missing Items From the Menu Toolbar
    By rmhaney267961 in forum AutoCAD Tips & Tricks
    Last Post: 2011-11-13, 10:33 AM
  3. mep section view/items missing
    By corr-what in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-02-23, 05:34 PM
  4. PDF Printing & Missing Items
    By SCShell in forum Revit Architecture - General
    Last Post: 2009-11-10, 02:09 PM
  5. missing families and items from 3d model??
    By greg.chapman in forum Revit Structure - General
    Last Post: 2008-07-10, 02:27 PM
