Search the Community
Ask, Learn and Solve
The AUGI forums are an online community where AUGI members
can discuss what they use everyday,
Autodesk Design Software!
  • Thread Tools
  • Display
    Default Exporting Floor Plans from Revit (Text)
    When I export a floor plan from Revit, how do I get the text information to appear? The text icon is grayed out in Navisworks. Is this because it exports as a 3D floor plan? Is there any way for it to appear 2D in Navisworks?
    2003-12
    Chicago
    206
    Default Re: Exporting Floor Plans from Revit (Text)
    We've found that the only way to get text from Revit to Navisworks is to go through AutoCAD.
    Essentially, we exported our column grid to AutoCAD and then brought the AutoCAD dwg into Navisworks - all our column grid numbers came in just fine.
    NavisWorks Moderator
    2004-07
    Fort Collins, CO
    1,329
    I also export to a 2d dwg to get room names
    The Silent Type
    2016-01
    San Francisco, CA
    293
    Yes, this is the solution for Revit Architecture 2009. Is Revit Archtiecture 2010 still having the same problem?
    Exporting the DWG of the floor plan works in 2010, however, it will come over in those pretty DWG colors but it can easily be changed.
  • Thread Tools
  1. AB416-3: Autodesk® Revit® for Conceptual Floor Plans
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:47 PM
  2. AB218-1: Autodesk® Revit® for Conceptual Floor Plans
    Last Post: 2014-11-30, 01:12 PM
  3. Conceptual Design and Floor Plans - Revit 2010
    By Brian Myers in forum Revit Architecture - General
    Last Post: 2009-11-07, 04:29 PM
  4. Exporting Revit Floor Plans to ADT
    By mmcclure in forum Revit Architecture - General
    Last Post: 2008-02-22, 06:31 PM
  5. Auto Cad floor plans to Revit
    By gallienhanson in forum Revit Architecture - General
    Last Post: 2005-01-12, 06:43 PM
