I have a bit of a problem with an image file that has the view rotated using the DVIEW TWIST feature. Which works fine, the problem is when the drawing is rotated the AutoCAD won't let me adjust the fade at all, but when the drawing is un-rotated it allows this. Is there a work around this problem or a permanent solution without un-rotating it?
Thanks
