Results 1 to 7 of 7
Thread: roof dormer....
    2006-04
    418
    Default roof dormer....
    i need for the ridge to be level....review attachment
    i did it in footprint (could be the problem)....i wasn't expecting this
    2007-06
    Melbourne, Australia
    602
    Default Re: roof dormer....
    Hi ntnik,
    In this circumstance, I would typically create a separate roof, adjust the pitch of this separate roof so that the the ridges are aligned and then use the join roof tool to stitch the two roofs together.
    Cheers,
    Ian
    2006-04
    418
    they are separate.....i did change to extrusion and it worked....was just surprised that doing it in footprint did this....i guess its the corner where they come together
    2007-06
    602
    I have had no problems in the past using footprint, but I will keep an eye out in the future.
    Cheers,
    All AUGI, all the time cphubb's Avatar
    2003-11
    Seattle
    691
    The problem with the Dormer is you made it 3 points. You need to make the roof rectangular and then use the join tool to get the valleys. See attached
    2004-06
    Memphis TN area
    7,048
    Also, are you using slope-defining edges, or slope arrows? If the dormer just comes to a point at the main fascia/eave, and doesn't extend out at all, then you'll have to use slope arrows.
    2006-04
    418
    hey, man.......you were dead on.......slope arrow did the trick
  1. 2015: Refit Roof/Dormer Issue
    By blastula99217487 in forum Revit Architecture - General
    Last Post: 2014-10-22, 01:09 PM
  2. Dormer Roof Vent
    By BomberAIA in forum Revit Architecture - Families
    Last Post: 2007-03-24, 07:22 PM
  3. Cut Roof for Dormer
    By matt.98118 in forum Revit Architecture - General
    Last Post: 2006-03-29, 11:09 AM
  4. Roof/Dormer issue
    By harkeychad in forum Revit Architecture - General
    Last Post: 2005-06-07, 06:46 PM
  5. Creating Dormer Roof Opening
    By Damo in forum Revit Architecture - General
    Last Post: 2005-05-06, 02:17 PM
