Results 1 to 6 of 6
Thread: The following render appearance images are missing
    2006-03
    London, UK
    810
    Default The following render appearance images are missing
    I'm getting this error when rendering. All files are on a network drive, in the same folder as the revit file. I left a render working overnight and everything was fine, this morning I'm test rendering in a new view and I get this error message. All custom images (material textures and decals) are reported missing and those items render with their default surface colour. I have to reassign them.
    Anyone know why this happens?
    2006-09
    The Kingdom of Denmark
    560
    Default Re: The following render appearance images are missing
    Don´t know WHY it´s happening, but it´s been hapening to me a lot lately... hmmm... maybe one should file a support request :O)
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    I get that sometimes too. I found that if you go to Settings->Options, Rendering Tab, and add the path/paths to the folders where those images are contained to your "Additional Render Appearance Paths" it fixes the errors. Doesn't seem like you should have to do that, but that's what's worked for me...
    2009-07
    3
    I have experienced the same problems regarding decals. I found that saving the image as in bmp-format in stead of jpg solved the issue.
    It leaves mw wondering why this caused problems at all, since jpg is one of the file types you can choose from in the decal settings...
    2006-09
    560
    I´ve been strugling with this isue for some time now, but can CONFIRM that using .bmp files seems to solve the problem - .jpg´s just seem to disapeer, even when getting the preview in the material dialog... Tommorow i´m gonna run a few more tests, and see if .png is any better (my preffered format anyway)
    AUGI Addict ws's Avatar
    Ambleside, Lake District, UK
    1,222
    This very subject popped up on the Revit Clinic today:
    http://revitclinic.typepad.com/my_we...e-missing.html
    There is a suggestion that it is the type of compression used in jpg files which causes problems.
  1. Render Appearance Paths
    By atowne in forum Revit Architecture - General
    Last Post: 2010-09-13, 01:57 PM
  2. Adding a new render appearance for an RPC
    By craighowie in forum Revit Architecture - General
    Last Post: 2010-07-19, 03:17 PM
  3. Render Appearance
    By spramanik in forum Revit Architecture - General
    Last Post: 2009-11-16, 08:58 AM
  4. RAC 2009 - Render Appearance images missing
    By designviz in forum Revit - Rendering
    Last Post: 2009-09-27, 03:26 AM
  5. Replies: 1
    Last Post: 2008-06-23, 10:50 PM
