Results 1 to 10 of 13
Thread: Help with Raster Image!!!
    Active Member kim.74445's Avatar
    73
    Angry Help with Raster Image!!!
    When I insert a raster image (JPEG) it is in the back and I can't bring it to the front. I need to place the image on a wall in an elevation and it only goes behind it so that it is not visible. How do I fix this???
    2002-02
    St. Louis, MO
    4,688
    Default Re: Help with Raster Image!!!
    Imported images are always the lowest layer in Revit.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    73
    Is there a way to fix that?
    I could stop if I wanted to jarod.tulanowski's Avatar
    2001-12
    Columbus, Ohio
    304
    it would be nice to be able to do that. my only answer is to put a decal on the wall or a masked material. within the wall
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    One way:
    You can place the image as a decal & then render the view. That'll make it show.
    When you place the image as a decal, you can select the wall face or picture frame face as the work plane, & the image will reside there.
    Then go to a 3d view, orient the view to that plane, and then render it.
    73
    I'm not sure I understand what you're saying to do...decal???
    73
    I want to avoid having to render the project if at all possible. Is there any other way?
    2002-02
    St. Louis, MO
    4,688
    Not in Revit. I've tried everything. I've also sent in reqests for display order of images. (I just wanted to use tiff scans of trees in my site plan and have them over buildings) I've also requested support for transparency and alpha channels.
    For now this type of work still has to be done in Photoshop.
    Aaron Rumple, AIA
    2003-05
    Waterville, Maine
    1,748
    Try this.
    Place the image in the elevation. Change the elevation's view to wireframe. If you get background stuff showing that you don't want ot see, turn on the far clip plane for the elevation, and adjust it to mask out stuff you don't want to see in the wireframe view.
    73
    Wireframe worked perfectly...thank you so much for the suggestion...I hadn't even thought of that. Once again, all of you saved me...thanks!
  1. FDO Raster Image Frame
    By kscolfer in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2012-03-26, 04:09 PM
  2. 2011: OLE vs Raster Image
    By smcgonagle in forum AutoCAD General
    Last Post: 2011-05-11, 12:02 PM
  3. Raster Image Bog Down
    By joseph_turc in forum Revit MEP - General
    Last Post: 2010-09-27, 04:16 PM
  4. No Raster Image in PDF
    By wayne.peterson in forum Raster Design - General
    Last Post: 2010-08-23, 11:13 AM
  5. Need Help Importing a Raster Image Please!
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2005-03-07, 12:57 PM
