Thread: Draw a line tangent to two circles
    Member pmg456037's Avatar
    2008-10
    Bel Air, MD
    15
    Default Draw a line tangent to two circles
    Hello,
    My apologies in advance if this is in the wrong forum or sub forum.
    I have two non-intersecting circles. For the question, the size, distance between and rotation, shouldn't matter.
    I need to draw a line tangent to both circles. How do I do that?
    I'm am trying to following, and it just doesn't work
    Polyline
    Tangent snap
    Select first circle
    Tangent snap
    Select second circle
    The problem is the first circle. The tangent snap isn't tanget.
    Thanks!
    2008-10
    Bel Air, MD
    15
    Default Re: Draw a line tangent to two circles
    Found an Answer.
    Someone in my office, heard my cussing and screaming and came up with a solution.
    Using LINE instead of POLYLINE allows you you rotate the tangent around the circle, unlike polyline.
    So I have to use a line and then convert it to a polyline.
    Thank you.
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Hi Patrick,
    I think that your thread should be in "AutoCAD General Forum" because the question doesn't have to be a 3D related issue.
    And try this.
    It draws a tangent line from arc to arc.
    (defun c:TANGENT_LINE (/ OSMODE_0 Pt01 Pt02 Entity1)
    (setq OSMODE_0 (getvar "osmode"))
    (setvar "osmode" 512)
    (setq Pt01 (getpoint "Select 1st point on a circle: ")
          Pt02 (getpoint "Select 2nd point on another circle: ")
    ); end of setq
    (if (/= PEDITACCEPT 1)
        (setvar "PEDITACCEPT" 1))
    (command "._line" "_tan" Pt01 "_tan" Pt02 "")
    (setq Entity1 (entlast))
    (command "._pedit" Entity1 "e" "exit" "")
    (setvar "osmode" OSMODE_0)
    (princ)
    ); end of program
    2011-02
    If you do not mind doing some math the attached pdf file depicts a method I have used for geting a line that is tangent to two circles and very accurat. And if you do not know how to rotate about a point it shows how to do that as well.
  1. Replies: 6
    Last Post: 2016-11-04, 03:11 PM
  2. Draw Arc tangent to Line
    By Jack Cheong in forum AutoCAD General
    Last Post: 2010-01-22, 08:35 PM
  3. Draw an Arc, tangent to two points...
    By Shizzjr in forum AutoCAD General
    Last Post: 2006-02-23, 11:56 PM
  4. Any way to draw an arc by tangent, tangent, radius?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2005-09-01, 01:49 PM
  5. Tangent Circles not Tangent
    By ccowgill in forum AutoCAD General
    Last Post: 2005-05-10, 03:04 PM
