Thread: No 3D training and a little stuck with something bound to be very simple
    2007-03
    18
    Default No 3D training and a little stuck with something bound to be very simple
    I've just about managed to create my drawing showing a mounting plate with equipment on it but need to add dimensions. Any dims I do add are either not showing as aligned to the side being measured or, if it's something on the z axis then it's dimnensioning as though it's on the x or y. How do I get it to dimension the way I want it to?
    0,0,0 The Origin
    8,570
    Default Re: No 3D training and a little stuck with something bound to be very simple
    Dimensions are always created at zero elevation in the current UCS.
    The easiest starting point is to set a current UCS using either "Face" or "OBject" option (of the UCS command).
    2015-10
    Vancouver Island
    107
    Normally I just do all my dimensions on paperspace.
    if I had to do it in model space I'd change the UCS xy axis for elevations etc
    100 Club Globey's Avatar
    2002-07
    Newington, Ct
    164
    I also have a dimensioning question. I can get my dimensions to line up properly, however, how to I get the text to align on a traditional xy axis, meaning horizontal, rather then aligned with the object? of course the dimension and extension lines with still be aligned, it's just the text I want rotated. Is it just a matter of rotating the text until you find the right alignment?
    Also, symbology. I am using Autocad 2008, without add ons.I just wanted to make sure that there is absolutely no GD&T symbology? Even though there is symbology referring to misc. items?
    2005-08
    Leeds, UK
    57
    Hi,
    I think attached picture shows the answer to your problem.
    Regards,
    Andrzej
  1. Replies: 1
    Last Post: 2016-04-25, 08:48 AM
  2. 2015 Training manuals In house training
    By boyerd492098 in forum CAD Management - General
    Last Post: 2015-02-05, 04:06 PM
  3. Replies: 0
    Last Post: 2013-03-30, 02:01 AM
  4. simple lables on simple entities
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2010-09-22, 09:38 PM
