I'd like to see a course on Tables and Fields.
Also, a courses on manipulating fields and tables with lisp
and VBA would be good.
Good idea, Mike. I find that a lot of users are avoiding some of the new features available in 2005 such as fields, tables, sheet set manager.
We're hoping to have someone with Autodesk that can present this. In the meantime, you may find the Autodesk webcast on it helpful. All are recorded so if you missed one you can view it anytime. There is one on fields.
http://usa.autodesk.com/adsk/servlet...linkID=2780444
Thanks for your input!
Beth,Originally Posted by acad
Do you have to be a subscription member to access these recordings? I tried and cant access them. Just says "sorry this meeting has already finished".
Thanks for the link tho.
Paul
No, you don't have to be a subscription member, but subscription members do have other training available through the subscription center.
The webcasts are complete, but normally recorded versions are available. If I see anything else, I'll let you know.
I just talked to Heidi that did the webcasts on AutoCAD 2005. They are in the process of getting the recorded versions completed and posted.
Keep checking that link and hopefully you'll see it soon!
But if the link is no longer active, did I just miss out? Will there be an ATP class? Will it be archived?Originally Posted by acad
HiOriginally Posted by ddraper
Try this link instead (should take you right to the Autodesk "AutoCAD Webcasts Archive").
Have a good one, Mike
Hi
Might want to take a look at the September 2005 offering "ATP090 Fields and tables combined to make a built-in spreadsheet" - Current ATP Courses.
Mike
