it is most likely a field as its the default
its too big to post
but this is the title anotation
<[Parent Alignment(CP)]>
H: 1"=<[Drawing Scale(P0|RN|AP|OF)]>
V: 1"=<[Graph View Vertical Scale(P0|RN|AP|OF)]>
there are few options for this item
its too big to post
the test scaling seems to be working properly now, its the label field thats causing the issues
i didnt create the styles, but im trying to fix them![]()
Ah! I get it! This is what you are seeing. It's not the SIZE of the label...
I think you're stuck doing it manually. Unfortunately, you can't put expressions into the label portion of a profile view style (at least not that I've been able to find).
what good is autoing it to the drawing scale?
man autodesk messed up again
We don't have that in our templates...... Did Autodesk do it or whoever created your template?
Playing around with it a bit, you can put an expression in a profile view label that gets the viewscale and then another expression that gets the viewscale/10. I this image, two viewports, different scales, same profile view and same label:
