Results 1 to 10 of 15
Thread: Dim's on Angles
    2003-12
    Jacksonville, Fl
    273
    Default Dim's on Angles
    Has anyone noticed you can dimension on the angle in 7 or could you do this before but I hadn't noticed till now?
    Pat Wm Smith
    2002-02
    52
    Default Re: Dim's on Angles
    Also, why does'nt the pick: Entire wall not work for angled walls.
    that tabing thru to get to the corner is time consuming.
    2003-05
    5,153
    Just to clarify ...
    Pat, dimensioning elements at angles is not a new feature.
    Mmolina, you can dimension entire angled walls. There are two ways -
    1. Select the wall, the temporary dimension appears - Convert it to a permanent dimension.
    2. Use the "Entire Wall " dimension button and select the angled wall.
    Cheers.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,268
    I have tried using a temp dimensions but they never appear at an angle. I have also tried using the entire wall feature but it doesn't allow the selection of the angled wall. The only way I have ever found to dimension an angled wall is the tab tab tab method.
    How do you manage to get a temp dimension at an angle?
    2003-12
    Jacksonville, Fl
    273
    beegee,
    How do you convert the temp dim to permenant?
    Pat Wm Smith
    2003-05
    5,153
    Click on the dimension symbol below the temporary dimension.
    Bruce Gow.
    Architect.
    Revitalize. Blog
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,532
    are you meaning a radiused wall? Radiused walls will not temp dimension as far as I know. Angled walls will though.
    Since 6.1 there has been an blue "dimension looking thing" below temp dimensions. Click it and it will turn the temp dimension into a permanent dimension...
    Steve
    2003-12
    Victoria, BC
    1,268
    I can get the temp dimension to work with a solitary angled wall, but once I attach another wall to it the temp dimension is no longer paralell to the angled wall.
    2002-02
    52
    Beegee,
    when's the last time you did a project with 1 wall?
    The only way to get the dim. on an angled wall is
    to do the TAB TAB TAB thing.
    2003-05
    5,153
    Like this you mean ?
    All done with temporary to permanent dimensions.
    Bruce Gow.
    Architect.
    Revitalize. Blog
  1. Angles
    By Jrobker in forum Revit MEP - General
    Last Post: 2009-09-24, 06:37 PM
  2. Arc Angles
    By r.c.russell in forum Revit - Student Support
    Last Post: 2009-06-19, 08:58 PM
  3. Change angles of Mtext to new Angles
    By darfnuggi in forum VBA/COM Interop
    Last Post: 2009-01-30, 06:03 AM
  4. Leader angles
    By GoDawgs in forum Revit Structure - General
    Last Post: 2008-11-13, 02:35 PM
  5. Angles
    By dsw98 in forum Revit Architecture - General
    Last Post: 2005-09-12, 06:32 PM
