Thread: Line Thickness' on Title Block when Imported
    2009-02
    11
    Default Line Thickness' on Title Block when Imported
    I have created a title block in Revit using Revits default line (ie. wide lines, medium lines, etc) When i insert it into the project file all of my thick lines are defaulted to very thin, and no difference between the thick or thin lines. I am sure I am doing something wrong and it is probably a simple answer, but I can't figure it out.
    Any help would be great.
    2007-09
    North Carolina
    66
    Default Re: Line Thickness' on Title Block when Imported
    Do you have Thin Lines turned on? (keyboard shortcut = TL)
    2003-04
    Chino, CA
    4,756
    Check the Object Styles for the Titleblock (Annotation Tab) in your project. For some reason they come out of the box with the line weights reversed for Thick and Thin.
    2009-02
    11
    Thin lines was turned off. In my object styles it had all my line thickness set to 1. I looked in there for lines but never title block. It looks much better. Is there anyway to use more than just thin, medium and wide lines to make a title block. I added new lines but when creating the family the new lines didn't show up in my pull down selection. (I am using Revit 09)
    2017-06
    I have created thick lines in a titleblock family by creating a sub-category under Title Blocks but when I load the family into a project the thick lines do not appear as such. I have TL turned on. I can see the styles I created in the list of available line types. Why don't the line types come across even when I delete and reload the Title Block family (in my project)?
    The lines appear correctly in the Family.
    - - - Updated - - -
    I worked it out.
    I opened the Family I created and used Transfer project standards to bring the line-types into the Project.
  1. 2013: Imported CAD file in title block does not look same in sheet view
    By ksuWallaceJ in forum Revit Architecture - General
    Last Post: 2013-06-13, 08:46 PM
  2. Thick line in Title Block
    By StephenJ in forum Revit Architecture - General
    Last Post: 2011-01-31, 10:07 PM
  3. line weights in a title block
    By ssmith.124120 in forum Revit Architecture - General
    Last Post: 2008-04-07, 02:08 PM
  4. Creating new line weights on Title Block Template
    By JAlmendras in forum Revit Architecture - General
    Last Post: 2006-01-17, 01:51 AM
  5. Convert MDT Title Block to Inventor 10 Title Block
    By julesgordon in forum Inventor - General
    Last Post: 2005-07-18, 08:34 PM
