If I create a lisp file to run a command that usually brings up a dialog box, the dialog box does not open. For example if I type Hatch, the hatch dialog box opens up but if I use the following code to shorten the command to HA the dialog box does not come up and the command line prompts you to input the pattern to use.
(DEFUN c:ha () (COMMAND "hatch"))
How can I get the dialog box to open using this method.
