Thread: circular hole opening
    2009-01
    345
    Default circular hole opening
    I'm using Revit MEP and I need to create a circular hole in a wall for a pipe to go through. Normally we don't get into the architectural things here because we are an MEP firm but this is kind of an unusual case that has me using the architectural aspects of the program I'm not familiar with. Can anyone point me in the right direction? I can make rectangular openings with the 'wall opening' menu under the 'opening' tab, but I cant make openings of any other shape.
    AUGI Addict ws's Avatar
    Ambleside, Lake District, UK
    1,222
    Default Re: circular hole opening
    If you just want a simple hole in the wall you could select the wall, view it in elevation or section and then click 'Edit Profile'.
    Draw the circle where you want it, click Finish Wall (tick mark button) and hole is made.
    2009-01
    345
    sweet! thank you!!
  1. Isolated Foundation opening / hole
    By djc1984 in forum Revit Structure - General
    Last Post: 2010-08-20, 10:08 AM
  2. Opening no rectangular en Pared Circular
    By carlos.197751 in forum Español - Revit
    Last Post: 2009-04-29, 01:16 PM
  3. Arch shape opening in circular wall
    By yuga_mane in forum Revit - Student Support
    Last Post: 2009-01-05, 09:21 AM
  4. AutoCAD 2008 Visual Styles - Show circular structure as circular not multi sided
    By robert.scragg in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-07-14, 02:38 PM
  5. Curved opening in circular wall
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2008-06-17, 04:13 AM
