Thread: Find and Replace command in AutoCAD 2009
    2008-06
    61
    Default Find and Replace command in AutoCAD 2009
    In previous versions of AutoCAD I used to use the find and replace command to find, for example a room number, once I get the zoom in of the room I canceled the command and I keep that zoom view, in AutoCAD 2009 it does not allow to keep the zoom view, once I close the find and replace dialog box it zooms back to the previous view..., it is something in the settings I can change to make it work as in previous versions of AutoCAD?, any suggestions?...
    Thanks a lot
    2004-08
    Iron Station, NC
    3,198
    Default Re: Find and Replace command in AutoCAD 2009
    Quote Originally Posted by oskyaqui View Post
    Thanks a lot
    I thought that was a bug, fixed with update 1 or 2
    Earth
    9,805
    Quote Originally Posted by ccowgill View Post
    Right.
    See: http://images.autodesk.com/adsk/file...update_20.html
    R.K. McSwain | CAD Panacea |
  1. 2012: Find/Replace command help
    By dmusika in forum AutoCAD General
    Last Post: 2012-10-16, 05:12 PM
  2. 2012: Find/Replace command for Dimension Text
    By WYSIWYG-BIM in forum Revit Architecture - General
    Last Post: 2012-05-11, 04:07 PM
  3. Find and Replace in AutoCAD 2009
    By ASRandall in forum CAD Standards
    Last Post: 2008-10-24, 11:03 PM
  4. Highlight Text From the Find and Replace Command
    Last Post: 2007-05-02, 05:12 PM
  5. Find and Replace Command
    By son.do in forum AutoCAD General
    Last Post: 2005-01-31, 10:40 PM
