Results 1 to 10 of 17
Thread: Error Handling
    2007-03
    32
    Default Error Handling
    I have lisp routines that set a variable for the user osnap settings. Different routines set different osnap settings then at the end of the routine it sets the osmode variable back to the user settings prior to running the command.
    When a user hits escape (or doesn't select anything during the routine and hits enter to end it) the routine does not get to the end to reset osmode to original user settings. I hear something about error handling in a lisp routinein which if a routine doesn't finish it puts the settings back to how the were prior to running the command.
    Can someone guide in how to write this in the lisp files.
    Thank you all.
    Houston
    9,348
    Default Re: Error Handling
    To get started, open the Developer Help, search for "error handling", then find the topic "Using the *error* Function". If this doesn't get you started towards solving your issue, post back.
    R.K. McSwain | CAD Panacea |
    2007-03
    32
    I'm still unable to figure this one out. I even found a site that shows how to handle this exact problem, and I can't get the lisp to work right.
    (defun *error* (msg)
    (setvar "osmode" *osnap)
    (princ msg)
    (princ)
    That's the code it tells me to write, but the osnap settings do not restore after an ESC cancel. I have *osnap set to read the users setting prior to the lisp changing osmode, and my lisp resets at the end if the lisp runs through properly. This works fine, but it still doesn't recall the user osmode setting after a cancel
    I'm adding my lisp routine. In the lisp I've posted I use "useros" in place of *osnap.
    2007-03
    32
    Sorry, the above posted lisp is the original...here's the one with the error handling code I can't get to work.
    2007-08
    201
    Hi,
    You have to nest and declare local your *error* function
    (defun MyFunction (/ *error* osnap)
        (princ msg)
        (princ)
      (setq osnap (getvar "OSMODE"))
      ;; do your stuff changing osmode here
      (setvar "OSMODE" osnap)
      (princ)
    2000-01
    Seattle WA USA
    5,857
    Lightbulb Re: Error Handling
    Quote Originally Posted by 'gile' View Post
        (princ msg)
        (princ)
      (princ)
    If you are going to go thru that amount of work, why not make the error routine also handle clean exits and dispense with the needlessly duplicated code? See the post here.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2007-08
    201
    Nice way Robert, you mean something like this ?
    (defun c:test (/ *error* osmode)
        (if (and msg
                 (null (member msg '("Function cancelled" "quit / exit abort")))
          (princ (strcat "\nError: " msg))
        (setvar "osmode" osmode)
        (princ)
      (setq osmode (getvar "OSMODE"))
      (*error* msg)
    2000-01
    Seattle WA USA
    5,857
        (if (and msg
        (princ)
      (*error* msg)
    Almost. It is just the last statement that needs a revision:
      (*error* nil)
    R. Robert Bell
    Stantec
    2007-03
    32
    Either I'm missing something or I just can't figure it out. I've tried all the mentioned ideas and haven't come up with anything that works. I can't even trouble shoot my attempts as I don't know if I'm even writing the right code in the right places. I'm pretty much just shooting in the dark (lisp at its finest LOL).
    I've attached my three attempts maybe someone can make heads or tails out of what my problem is. Note1.lsp jams up ACAD and I have to go to the task manager to close it. By the way I'm using ACAD 2010 if that changes anything.
    I don't want it written for me, I won't learn anything that way, but if I had a little more guidance about where I was going wrong I may be able to get an the right path.
    Thanks again for everyones patienece and advice.
    2003-12
    Pittsburgh, PA
    355
    Maybe this will be of interest to you
    http://www.afralisp.net/lispa/lisp6.htm
  1. Error Handling
    By whattaz13 in forum AutoLISP
    Last Post: 2008-07-16, 01:03 PM
  2. Error Handling
    By jwf in forum AutoCAD Customization
    Last Post: 2004-12-03, 07:42 PM
  3. VBA Error Handling
    By msretenovic in forum ATP Course Wishlist
    Last Post: 2004-09-17, 07:58 PM
  4. Error Handling:
    By spencer.67965 in forum AutoLISP
    Last Post: 2004-09-15, 09:18 PM
