Thread: Elevation Grid marker
    2006-09
    259
    Default Elevation Grid marker
    I am creating a detail component family for elevation grid for room loading. In this family i have one horizontal line and one vertical line. They both array with set spacing. It works fine. But i want to add height at the end of each vertical line arrayed. So lets say vertical array spacing is 300mm then the bottom line will show 0, then next one up shows 300, and next one up shows 600 etc. How do i achieve this?
    Please see attached image of elevation grid. this is what i want to achieve.
    Thanks in anticipation of your help.
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: Elevation Grid marker
    Rahul
    Load the Grid Rfa into your project.
    Go to the elevation view and place the grid as needed.
    Drafting > Spot Dimension > Spot Elevation : dimension the horizontal lines of the grid.
    Changing the spacing settings of the Grid Rfa > Spot dimensions shall follow
    Notice also you can change the Relative Base of the Spot Dimensions
    Where can i find the grid.rfa?
    Thanks in advance
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    grid rfa - Eddy means your detail component of lines, load it in to your project then use the Spot Elevation tool
    If used on more than one instance - group it together so one change updates elsewhere
  1. 2013: elevation marker related to specific elevation view
    By Ning Zhou in forum Revit - API
    Last Post: 2013-02-22, 02:07 AM
  2. ASD Steel Elevation Marker
    By mhr in forum AutoCAD Structural Detailing
    Last Post: 2010-10-06, 03:50 PM
  3. elevation marker
    By olakahahola in forum Revit Architecture - General
    Last Post: 2010-09-25, 11:36 AM
  4. Elevation Marker
    By STHRevit in forum Revit Architecture - General
    Last Post: 2009-01-29, 10:31 PM
