have never had this happen to me before. When I render my model I cant see it in the render window. I am using ACA 2008. My layers are not frozen or anything like that. I have no clue as to why this is happen.
Dumb question, but you didn't somehow move the camera or have the render window set up to match a view that doesn't look at the model? Maybe your to perspective or to far away? Just some thoughts.
Dave Peterson
Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
"The more you know, the less you know, because the more you know you don't know". --M. Lin
I played with the camera and not even. So I did what I go against--I gave up and started anew. Sometimes I have to know my limits. Thanks for your help though.
I didnt finish my bad, I started anew and everything works great my render window has not issues. I must have turned something on or off and didnt know it. Likely I had just started a fresh dwg--nothing lost nothing gained.
Good,
I was going to say, just take your model and copy and paste it into a new drawing started from a template. That usually fixes any issues. Not sure what ACA hangs like that sometimes, but it does
Dave Peterson
Hi,
I had a similar problem and just lately. I assumed it was that I pushed the hardware to the limits, I have 2 gb Ram (max) for the motherbd in the system. I've got to say wrigthly or wrongly it didn't happen before the ACA2009 upgrade was loaded. It's more than likely the sys is overloaded, but it has happened , I usually try three of four times then close all down and reopen, and it's back.
Dave
(CDM)
