Thread: REVIT 2010 - dwglink layer management?
    2008-02
    29
    Default REVIT 2010 - dwglink layer management?
    If I link a drawing into 2010 to use as a background, can I turn on and off layers? I would like to do that so I can de-clutter the areas in which I want to use it as a base for layout of walls etc. But then I would like to turn them back on later. I see under the import instance tab there is a Delete Layers, and Query option but no on/off or freeze/thaw. Also I cannot use the normal temporary hide/isolate tool as it will only select the whole dwglinked file. Thanks for any advice.
    Regards Peter
    Member psteel's Avatar
    2006-05
    London, England
    37
    Default Re: REVIT 2010 - dwglink layer management?
    Under View Graphics ( VG ) you can select DWG layers in the Imported Catergories tab.
    These will switch off / on etc but only for that view.
    If we are using a DWG for background only, we tend to copy the file, clean it up in ACAD
    and then import it as a link.
    This way what you import is what you get, no switching on and off etc.
    Hope this hepls.
    2006-01
    4,516
    Hit query | Select a line in the Linked DWG | It will show you the stats of the line/layer | Select Hide in View.
    All that is really doing is going in to the VV/VG dialogue and going under Imported Objects and unchecked certain layers, which is another way you can do it...
    Pittsburgh, PA USA
    1,906
    Just beware, Any layers you do "turn off in a few" seem to turn back on when the view in Revit is exported back out to a DWG file. We have clients that want a set of "bound" DWG files at the end of the project, but yhou need to be aware of this issue.
    We create a copy of the DWG, and delete any information and layers that we won't want exported back out to a DWG.
  1. Why Revit 2010 Crash, while deleting any Function Material Layer of Floor?
    By bingles7 in forum Revit Architecture - General
    Last Post: 2010-05-06, 05:13 PM
  2. layer management
    By dstarr in forum Training
    Last Post: 2010-01-25, 11:31 PM
  3. Layer Management
    By Spanky in forum AutoCAD General
    Last Post: 2007-08-17, 02:08 PM
  4. Layer Management
    By jbayne in forum ACA General
    Last Post: 2005-05-09, 09:47 PM
  5. Layer Management
    By Chuckyd67 in forum ACA Wish List
    Last Post: 2005-03-01, 11:48 PM
