Sorry if this has been dealt with before, i have looked all over these forums and have not been able to find a solution.
I am working on a conceptual mass that looks fairly complex, but was a simple spline through points, extruded up, with several profiles added to it, which were then scaled to give a tapered look. (See pic)
I then click on one of the faces of the model (these are not edges i have added, but i presume where the spline points were on the base.) and try to pattern it.
A pattern appears, but i do not have the ability to change this to say, a triangulated pattern, or a family i have already made, which is what i really need.
I would rather not have to remodel this shape, and in the same file i even tried to make a simple extruded rectange, which had the same problem.
Thanks for your help!
