Yet another problem with Linked AutoCAD files….
Hey guys, I don’t post often here because a quick search of the forum usually answers most of my questions…unfortunately that is not the case this time!
I am having a problem “reloading” an AutoCAD file that has been linked in. It should be noted that this project is using worksets.
One day, I randomly got the message/error upon opening to the effect that: “Revit cannot locate following DWG, or it has been moved. Revit will display the file as it was the last time it has been updated. Use ‘manage links’ to repair the link.” I don’t really know where this is coming from, since the file has not moved in 4 four months!
I tried to do what it says: I went into ‘manage links’ and did the ‘reload from’ to manually tell it where the file is (and also was) - but the odd thing is that it never updated and reloaded. In an attempt to force it to recognize the new location, I UNLOADED (not to be confused with removed) the link, and then tried the ‘reload from’ command again. It didn’t work. It now thinks the file is still unloaded, and I can not get it to reload even the old “last save state” version.
This is very frustrating, and has happened before. The way I have resolved it before is to remove the link, only to reload and relink it in. I really do not want to do this because at our firm we typically do all of the site work in ACAD (since the site tools in Revit are not developed enough) – and this particular project is more involved with the site than some of our previous projects, and as a consequence has a great deal more graphic overrides associated with layers and I do not want to lose that information, or redo it. Anyone have any ideas on how to fix this? What could I be doing wrong?
FWIW – the site is drawn very close to the origin in acad, and the coordinates have been acquired and resaved backed into the dwg along time ago when the project first started.
Sorry for the long post, but wanted to explain the etire situation – since I have seen enough threads on here to know that the more info the better. Have a great day!
