Results 1 to 8 of 8
Thread: Dwg to Tiff
    I could stop if I wanted to nextvkin's Avatar
    2007-07
    317
    Default Dwg to Tiff
    Hi all,
    I need to convert a set of dwg files to tiff as 1 document; I managed to convert the dwg first to pdf then through Acrobat saved as tiff, but they come as separate documents. Can anyone help? Thanks.
    2007-07
    Jo'burg SA
    4,348
    Default Re: Dwg to Tiff
    I use PDFCreator for this. Plot from ACAD to PDFCreator. Then when the setting dialog pops up, click the Wait-Collect button. Repeat all the plots you want, even using the PUBLISH command. Then in the PDFCreator's list view, select all of them, click the combine toolbar button & click the print button. When asked for filename, change the extension to TIF.
    Only prob is it creates an uncompressed TIF file ... but that can be remedied with an image editor.
    2007-07
    317
    Thanks for that, irneb, I'll have to d/l a copy of that right? Then I'll give it a shot.
    2007-07
    Jo'burg SA
    4,348
    That's one solution, and the one I use. But there's quite a few others with similar capabilities out there. Here's the PDFCreator page. But you can google PDF printer driver for others if you like.
    Another way of doing it is to combine the TIF files after Acrobat Reader has exported them. For this you'll require an image editor capable of this. One I like (because it's free and works on multiple files at once) is XnView.
    2007-07
    317
    Thanks again, will check them out.
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,180
    AutoCAD also has a feature called tifout that might help.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    I use Acroplot Pro by Cadzation. It exports to many formats, including PDF, TIF, PNG, & GIF.
    It's not free, but if you export to these formats often, it may be worth a look.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2007-07
    317
    Thanks for the suggestions, Railrose & Scott, they're handy to know.
  1. TIFF lineweights
    By dwahl in forum AutoCAD Plotting
    Last Post: 2010-07-20, 10:18 AM
  2. pdf or tiff to dwg
    By ndiamo4669 in forum Software
    Last Post: 2009-05-14, 07:45 PM
  3. DWG to TIFF 400dpi
    By kague in forum AutoCAD General
    Last Post: 2006-05-12, 05:29 AM
  4. DWG to TIFF
    By cosnobum02 in forum AutoCAD General
    Last Post: 2006-02-21, 02:51 PM
  5. TIFF viewer in VB
    By Coolmo in forum VBA/COM Interop
    Last Post: 2004-07-24, 04:10 AM
