Thread: DWFx the way to go?
    I could stop if I wanted to Liamnacuac's Avatar
    2005-12
    Earth
    441
    Default DWFx the way to go?
    I haven't invested any time into learning about Microsoft's XML or XPS formatting until a few minutes ago. My understanding is that it allows better data exchange between programs?
    If my understanding is correct, then does that mean there are more opportunities to search for information in a drawing if it is printed in .DWFx? Other than Autodesk products, can other programs access information inbedded in the file? I know i can open the files with internet explorer...
    I'm considering whether it makes sense to change our "electronic deliverables' to include .DWFx files, .XPS files, or continue with the more universal .PDF files (at least here in the US), as I understand the files are considerably bigger. I created a .XPS file and it was SMALLER than my drawing file (176 Kb vs 220). The .dwfx was smaller yet, so I'm confused a little about any added data....
    So does anyone else have any thoughts? Is using dwfx a no brainer, or has it not caught on (personally I would rather send a file most everyone can read, or download free software easily to read it, than have proprietary formatting that requires a bit more work in finding and installing)?
    2007-04
    81
    Default Re: DWFx the way to go?
    I would probably check what version you need of internet explorer. Of course you do have the users of other explorer that probably would not be able to read it without internet explore or the free download from autodesk. But you are correct that it is a much smaller file than any other.
    Patrick K. Johnson
    http:\\www.cadenhancement.com
  1. DWFx Crash
    By art.theusch in forum NavisWorks - General
    Last Post: 2013-03-01, 12:43 PM
  2. dwfx into Navisworks
    By rj.reed in forum NavisWorks - General
    Last Post: 2012-02-10, 01:14 PM
  3. DWFx to DWF converter?
    By jsanner208516 in forum DWF Viewer - General
    Last Post: 2011-10-13, 02:10 AM
  4. Trying to Compare DWFx files
    By mmiles in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-08-03, 07:20 PM
  5. DWFx pc3 file 2009
    By dzatto in forum AutoCAD Plotting
    Last Post: 2008-04-11, 03:41 PM
