Results 1 to 8 of 8
Thread: arg. profile file won't load
    2005-01
    115
    Default arg. profile file won't load
    When I start AutoCAD ADT, it goes to the default arg. file, even if I set my profile to current after startup. So my default templates, etc will not load upon startup.
    acad.lsp it set to load with my profile. Everything appears to be pathed correctly with my custom arg. but it does not help since the arg. does not load
    Any help appreciated
    Mike
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    Default Re: arg. profile file won't load
    There may be a /p switch in your shortcut icon that is loading a profile that is not current.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2005-01
    115
    How can I change this? I see if I open props in my shortcut, there is a long path in the target field. But not sure if I should mess with it.
    Mike
    Houston
    7,519
    If you tell AutoCAD to load a certain ARG file at startup, and there is an existing profile with the same name, the ARG file is ignored.
    2001-01
    Edmonton, Alberta
    961
    Quote Originally Posted by jocques View Post
    Mike
    Look for something like
    /p "profilename"
    at the end of the target line, and remove it, or make a copy of the shortcut and edit the copy.
    2005-01
    115
    They have different names, There is the out of the box default profile (Arch Imperial), then the profile I created (Mike), but the default profile was reset, so now it always opens the default profile. I always thought AutoCAD would remember the profile you set as current, along with all the file paths...
    but it sounds like I have to do one of the following:
    customize the default profile
    change the target in the shortcut
    Does this sound right?
    Mike
    2001-01
    Edmonton, Alberta
    961
    Removing the /p in the target should load the last current profile.
    0,0,0 The Origin
    8,027
    Try renaming the file from myprofile.arg to myprofile.reg. Double-click it then open acad and see what's happened. Rename it afterward.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  1. Error opening AutoCAD - unable to load profile file
    By jsieszycki in forum CAD Management - General
    Last Post: 2010-11-16, 05:36 PM
  2. Load Deck Profile???!
    By aaronhacker92 in forum Revit Architecture - General
    Last Post: 2010-06-20, 12:05 PM
  3. Load Different Profile (arg) With a Drawing
    By CADdancer in forum AutoLISP
    Last Post: 2008-07-07, 12:54 PM
  4. Unable to Load Profile
    By quigin in forum DWG TrueView - General
    Last Post: 2007-11-21, 04:53 PM
  5. Profile file will not load
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-07-11, 03:59 AM
