Thread: AcitveDocument.Elements v. ActiveDocument.ActiveView.Elements
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    Default AcitveDocument.Elements v. ActiveDocument.ActiveView.Elements
    I'm trying to get an element set from the active view using a some code from th DevTV tutorials. This works to grab an element set from the entire model:
    ElementSet elems = revitApp.Create.NewElementSet();
    ElementIterator iter = revitApp.ActiveDocument.Elements;
    while (iter.MoveNext())
    So I assumed that changing it to
    ElementIterator iter = revitApp.ActiveDocument.ActiveView.Elements;
    Would allow me to work from the active view element set however, I'm getting the error:
    "Cannot implicitly convert type 'Autodesk.Revit.ElementSet' to 'Autodesk.Revit.ElementIterator'"
    Any insight into why this happens and what the type difference between the Elements object in ActiveDocument is compared to ActiveView?
    TIA,
    2005-09
    69
    Default Re: AcitveDocument.Elements v. ActiveDocument.ActiveView.Elements
    Because the ActiveDocument property is of type ElementIterator
    From the ElementSet returned from the ActiveView, you can use ForwardIterator which returns an ElementSetIterator (note the subtle difference there as well)
    2006-01
    449
    Thanks David. I'm slowly beginning to understand these subtle differences but your response helped complete my understanding.
    I could stop if I wanted to Danny Polkinhorn's Avatar
    2003-12
    Honolulu, HI
    447
    This is one of the inconsistencies with the API that drives me nuts.
    Danny Polkinhorn
    WATG
  1. Elements in linked files obscure local elements
    By JoelB in forum Revit - Platform
    Last Post: 2010-11-15, 06:30 PM
  2. Replies: 3
    Last Post: 2009-08-07, 05:34 PM
  3. Problems about "ActiveDocument.ActiveView"
    By wenshin in forum Revit - API
    Last Post: 2008-04-17, 01:37 PM
  4. Detail Lines are model elements, how about annotation elements?
    By scowsert in forum Revit Architecture - General
    Last Post: 2007-08-03, 07:08 PM
