Thread: GeoTIFs
    2009-07
    Default GeoTIFs
    Does anyone know how to create a geoTIF from an attached image that has been georeferenced in AutoCAD?
    TN/KY Area
    1,640
    Default Re: GeoTIFs
    You need to use Raster Design to create a geoTIF. However if you know the scale factor and insertion points you can write a world file in notepad and save it with the same name as the tif to make it a georef tif. There's also some 3rd party tools out there that do it, take a look at MapTools from dotsoft.
    2007-10
    3
    Default Re: GeoTIFs
    Quote Originally Posted by david.andrews View Post
    There is a LISP plug in that can insert and export an image file from standard AutoCAD.
    If I remember it is called "ABC Raster manager" it adds an extra tool bar in AutoCAD that allows you to write a world file based on the inserted coordinated of an image.
    I'm sure a search on google will find it.
    Pete
